How to replace starter???
Old 07-14-2006 | 06:47 PM
hyrumbradshaw's Avatar
Default How to replace starter???
1998 accord v6 auto, wont start, clicking noise. I had it jumped and it started. alternator replaced recently and battery has been tested. cleaned terminals and still wont start. the guy at auto zone said its probably a starter selenoid. do I have to replace both the starter and selenoid? does anyone have instructions or pics that would help me replace starter?
Old 07-14-2006 | 10:48 PM
YeuEmMaiMai's Avatar
Default RE: How to replace starter???
ask DH
i believe by looking at the pictures that the starter assembly is on the front of the trans and is fairly easy to get to.
I would take the starter off and get it tested before you plunk down the $400 for a new one....
Old 07-15-2006 | 01:20 AM
deserthonda's Avatar
ORIGINAL: hyrumbradshaw
to replace the starter, first off make sure you got the code for the radio ( anti-theft) , disconnect the neg battery cable, remove the nut ( 12 mm ) for the starter cable goint from battery into the starter , disconnect the wire going to solenoid.. ( black/white wire ) ,, there might be the clamp for the AT cooler hose in the way , remove it,, remove the 2 14mm bolts that hold the starter on, remove the starter,,,,,,,,,
Reinstall in reverse order,,,,,,As alway make sure all bolts and nuts are tight and wires properly clamped on .........
HossKhaos
11-23-2017 08:24 PM
SaveTheManuals
01-17-2015 06:39 PM
manny4acura
10-18-2011 09:05 PM
aznskater51
04-14-2011 05:02 PM
daemonhat
03-26-2006 09:58 AM
Quick Reply: How to replace starter???
