how to replace the Turn signal flasher?
Hi Everyone!!
I'm new in this forums and i hope i can find help with my Accord 2007.
i have 3 main issues which i will comment in the respective forum.
First of them is the Turn signal flasher.
when i activate the turn signal it ligths on a couple of times and then starts to make the shortcut sound like a buzz and the light blink as shorcut. After that it doesn´t work. Is the same with the parking light.
I noticed if i make this several times after a minute or two works again as nothing happen probably cause the flasher gets hot or something.
I believe the flasher is not working properly and i would like to know how to replace it.
I don´t know where is it placed.
Could you help me with this issue?
Is there any tutorial in you tube or a piece-map?
maybe a step-by-step or something
Thanks guys, I´ll wait some response from you.
PeterFlorida
02-26-2013 10:09 AM
1ATony
01-27-2011 04:42 PM
