I feel like I'm on the short yellow BUS!!!
Front Rotor Nightmare!!!
All I wanna do is change the front rotors on my 94 Accord EX! WHAT WERE THEY THINKING!!!!! I have the left side apart and thw hub will not come OFF!!!!!!!!!!!!!!!!!!!!! Do I need a puller???? Any help would be great! TY
How do you make a car where you have to take the whole front end off to change a ROTOR!!!! What the HELL where they thinking!!!! So I have a 1994 Accord and I can't get the hub off......WTH do I need a puller?
BEEP: wrong answer, not that kind of set-up, rotor is mounted between the hub and the knuckle and honda recommends turning on the car if within spec and they even want you to turn them after they are installed on the car...not one of their better ideas
I've changed the rotors twice on Honda's hub over rotor setups. Its not that bad really, about an hour per side if you've done it before. The hardest part for me was getting off the axle nut. I don't have the right socket and have to use a hammer and chisel.
