I need help with a funny noise
I am new to this site, and i just got a used accord. I am loving the ride and how it saves me money on gas. But I do have a couple of problems with the car. I found most of the answers by searching the forums. Now the problem I have is that my car makes a screeching sound when in park and when on the move, but when I push the clutch pedal the sound stops. When I let go of the clutch the sound comes back. Should I be worried? Any help would be great.
The throw out bearing should not spin when your foot is off of the clutch pedal. So it shouldn't make any noise.
I wonder if you push or pull release arm back towards the slave cylinder if the noise will go away?
PA, are you sure? There's a weak spring inside the clutch slave cylinder, that pushes the T-O bearing lightly against the pressure plate.
Sounds like a noisy T-O bearing to me. Kinda common to get noisy when lightly held, but gets quiet with more force against the pressure plate.
I made a video I hope this is more helpful with the problem that I am having.
http://www.youtube.com/watch?v=tpnmzRlWLuo
