Idle on 99 accord ex coupe
Old 08-24-2008 | 10:07 AM
phantom309
Default Idle on 99 accord ex coupe
Just bought this and it ran great on the drive home and this morning it will not run unlessgas pedel is lightly appied.Runs fine if you get it moving but you stop and it dies. Thanks in advance. Tim
Old 08-24-2008 | 11:07 AM
Default RE: Idle on 99 accord ex coupe
This is usually caused by dirty throttle plate/bore and dirty idle air control valve and idle air passages. Clean w/ throttle body plate/bore w/ throttle body cleaner and old toothbrush. Wipe clean w/ paper towel. Remove IACV and clean valve body and inlet/out air passages w/ throttle body cleaner. Avoid in throttle body cleaner on IACV solenoid as it may damage winding.
Old 08-24-2008 | 06:17 PM
phantom309
Thank you ,I pulled the bodyand cleaned it very good and its back to normal. Thanks Tim
Kpick
05-05-2015 09:51 PM
HatchJunki
03-09-2013 09:23 AM
90pioneer
04-09-2012 10:06 PM
RWilliams
07-24-2011 10:16 PM
fperezal
06-14-2006 06:03 AM
