idle drops from intermittenly
Hi,
Posted before on this topic. 95 accord vtech codes are clear high milage 250k running well.
At idle when stoped in gear on and off the idle will drop about 100 rpms havent put it on a tach just using the one in the dash. When the idle drops the car runs rough meaing you can feel a shake. Any advise appreciated.
Lee
Lee
RE: idle drops from intermittenly
pull loose the IACV and use some Berrymans B-12 to blast out all the soot from the screen.
Then while you have the Berrymans in your hand, grab up a softbristle brush [wifes toothbrush works great] and scrub out the ring of crud around the throttle plate.
I hold the throttle open by using a long screw driver under the cable and bracing it on the top of the intake.
RE: idle drops intermittenly
up date, cleaned the throttle plate and body, sorry no B12 in ny good ole gumout. The body looked clean, the plate was dirty looks already cleaned the IAC. Lasted for about a day now back to idle dropping and rough. Any further ideas appreciated.
Lee
Lee
swhitney11
10-14-2008 08:45 PM
