idle hunt
Old 10-27-2008 | 09:55 PM
petercampusa
Default idle hunt
i have a 1991 accord lx and when in park or neutral the idle goes up and down but in drive or reverse it doesnt. anyone had this problem?
Old 10-27-2008 | 10:53 PM
finch13's Avatar
Default RE: idle hunt
It could be you're Idle Air Control Valve on the backside of the intake manifold being gunked up with carbon and not opening. This is what allows air into the cylinders when the throttle plate is closed (foot off the pedal)
Old 10-28-2008 | 01:35 PM
klrspz's Avatar
Or a PVC Valve... which is really cheap and easy to fix.
Old 10-28-2008 | 01:41 PM
finch13's Avatar
ORIGINAL: klrspz
Or a PCV Valve... which is really cheap and easy to fix.
Fixed it for ya ;-). Try PCV first, they're like $4 max. I personally would get a NAPA one, all others I've gotten tend to break apart.
Old 10-28-2008 | 04:32 PM
cjdm98's Avatar
On my old Integra, i had the same problem, I cleaned the IACV with Carb cleaner, and it worked fine after that, tweeked the distributor a bit to get the perfect idle.
90pioneer
04-09-2012 10:06 PM
RWilliams
07-24-2011 10:16 PM
donniejr81
12-26-2010 11:26 PM
petercampusa
10-28-2008 09:54 PM
fperezal
06-14-2006 06:03 AM
