Ignition switch help!
97 Accord Ignition Switch Removal & Replacement
Here's a two part Youtube video I found recently that does a good job of explaining and demonstrating a switch replacement.
94-97 Honda Accord Ignition Switch Replacement Part 1 - YouTube
94-97 Honda Accord Ignition Switch Replacement Part 2 - YouTube
Not too bad. See this link:
https://www.hondaaccordforum.com/for...problem-42750/
All you would be replacing would be the electrical switch portion, not the entire ignition switch body. If you don't have the service manual, go to the DIY sticky at the top for the link to the service manual.
Since there is the airbag in the area, disconnect the battery for several minutes before performing any work.
