Immobiler System Problem
Old 07-19-2006 | 01:06 PM
Bobj
Default Immobiler System Problem
Hello Everyone, I am new to the forum. I have a 1999 Accord V-6 that has problem with the Immobilizer I believe. When driving along at a steady speed the engine will suddenly die. After pulling over to the side it usually starts right up. This has happened 4 time in the last year. Yesterday it did the same thing twice, when it did it the second time it was at night and I noticed the immobilizer system light flashing.
Has anyone else had a similar problem and if so what did you do to repair it. Any help would be greatly appreciated.
Thanks: Bob J
Old 07-19-2006 | 08:58 PM
Chiovnidca's Avatar
Default RE: Immobiler System Problem
Has the ignition switch recall been done? That's what it sounds like.
Old 07-19-2006 | 09:25 PM
YeuEmMaiMai's Avatar
that isn't the immobilizer. Once the car ID's the key as being the correct one, the immobilizer allows the car to START and the ECU takes it from there.
Like Chiovnidca said it is most likely your ignition switch that has failed. Symptoms include sudden stalling when driving the car.
You need to take your car to your local honda dealer and check to see if the recall was done and if not get it done, If it was done, see if you can get a good will repair done.
Old 07-19-2006 | 11:54 PM
mbo1985's Avatar
yeah man, like everyone said, sounds like that switch.
live2rice
09-03-2012 01:34 PM
sajeed
07-03-2008 01:36 AM
tduncan
09-19-2007 10:32 AM
bboyalex
07-16-2007 02:51 PM
codyheit
02-27-2006 06:11 PM
