installing an aftermarket temp gauge
Old 06-12-2006 | 04:33 PM
sportsman1539's Avatar
Default installing an aftermarket temp gauge
i have an aftermarket temp gauge on my car right now but i dont know how to hook it up. the guy that had the car before attempted to hook it up but its just not working. how do you hook it up? i was guessing somewhere around the thermostat but i really dont know. thanks
Old 06-12-2006 | 07:09 PM
sir_nasty's Avatar
Default RE: installing an aftermarket temp gauge
there should be a temp sensor right around the thermostat (I believe it's towards the back of the car from the thermostat) it's usually only two wire. what year/model do you have?
Old 06-12-2006 | 07:17 PM
its a 94 lx. it looks like he has it wired up to the sensor thing that hooks into the thermostat. i think its hooked up wrong.
Old 06-12-2006 | 07:22 PM
sir_nasty's Avatar
is it either backwards by chance? check with a voltage meter and make sure it's even giving off a reading....
Old 06-13-2006 | 02:17 PM
fperezal's Avatar
Electrical or thermal? If is thermal, go to the top hose where it goes to the engine. Go to this link temp_gauge and you will see a drawing I made for you. I done this 4 times with no leaks at all. When bending the probe into the water outlet/hose pipe, cut a little of the spring (dont cut the copper; be very careful) and insert only the thin copper line. Be careful when bending this. Let me know if you like my idea.
pirulino23
11-10-2010 07:18 PM
raf105
09-28-2007 03:55 PM
corr04
06-07-2006 02:24 AM
honker3
12-06-2005 09:33 PM
fperezal
09-29-2005 10:29 PM
