interior trunk lock help
Old 10-02-2007 | 01:04 PM
sosaman's Avatar
Default interior trunk lock help
hello, i need help with trying to fix this also. when my g/f's car got broke into (other thread), they also screwed up the interior lock (for the handle), for the trunk. is there anyway that i can fix this? i have not really taken a look at it, but i opens in the locked and unlocked position. i'm more worried about fixing the ignition lock (other thread here), so we can get back to 2 running vehicles. thx, sos
http://www.flickr.com/photos/9608276@N05/1472860840/
Old 10-02-2007 | 01:29 PM
sir_nasty's Avatar
Default RE: interior trunk lock help
Depending on what part you need here's a parts list and breakdown of the ignition...
http://www.hondapartswarehouse.com/p...t6=B%20%201105
Here is the steering column
http://www.hondapartswarehouse.com/p...%20%2032%20%20
I'm not certain though where the trunk assembly stuff is...
Old 10-04-2007 | 07:08 PM
nafango2's Avatar
theres a little cover on the trunk pop thing with a screw under it.
unscrew that and remove the trunk pop assembly. look bent/broken retaining clips. they most likely stuck a screwdriver in and twisted until the pieces of plastic that stop the exterior of the lock broke.
Old 10-07-2007 | 12:28 PM
sosaman's Avatar
thx, i'll check it out later on. for now i took everything out of the trunk (that was worth anything). my next focus is putting in some type of kill switch (or something). - sos
Agregory88
12-09-2012 10:54 AM
thaison86
06-28-2012 01:03 AM
drew&dixon1718
11-29-2011 10:31 PM
Azrael
02-23-2009 06:33 PM
MNHONDAGUY
05-08-2007 08:52 PM
