Issue after brake fluid change
Old 07-28-2013 | 06:54 PM
Small bubbles are a consequence of vacuum bleeding and don't cause a problem as they don't get into any permanent fluid in the system. They occure when air enters around the loose bleeder into stream leaving the caliper.
Old 07-28-2013 | 07:13 PM
LS-300's Avatar
Thanks! I was starting to freak out. I haven't done it in a while and don't remember having all the tiny bubbles.
  #23
Old 07-28-2013 | 08:02 PM
After a lifetime of pedal pump bleeding I bought a vacuum bleeder from Harbor Freight. I've done 5 vehicles now w/o problems.
Some folks remove the bleeder and pack grease around the bleeder to prevent air bubbles. I suspected there would be no problems w/ allowing bubbles to enter at the bleeder and this has proved to be the case. No problems w/ soft pedal at all.
Old 07-29-2013 | 12:05 PM
I used a vacuum bleeder and get all the tiny bubbles. I tried to pack grease around the base of the bleed screw, without removing the bleed screw. That was a big improvement, but it's difficult to smear the grease around without leaving an opening somewhere.
But then I got a pressure bleeder and I like that a little better yet.
93Accord2.2
12-17-2021 10:59 AM
62maxx
10-18-2015 09:20 AM
logannz
03-30-2013 06:20 AM
93Accord2.2
01-20-2012 02:02 PM
62maxx
11-21-2006 01:04 PM
