j series build questions
Old 07-08-2011 | 03:39 PM
jester1020's Avatar
Default j series build questions
Ok, so I've been gathering parts for awhile now and i'm just about ready for my first j series build. I have a set of j32a2 heads minus cams (hey it was free) and a j35a4 long block. I've been doing a lot of reading and only have a few questions. I know that you can use acura pistons to clear the valves but then you get somewhere between 10.5 and 11.5 compression depending on which pistons you use. That's just a little high for me. I have read that j30a3 pistons can be used and have enough clearance and keep compression down around 9.8 Has anyone ever used them to know for sure?
Old 07-08-2011 | 04:58 PM
Tek310's Avatar
im gonna be real, this is probably something better suited for honda-tech.com
dont believe we have many j-series guru's here.
also post on dallasimports.net tons of honda gear heads there. been with them since 05.
Jeffaccord
02-06-2012 09:58 PM
HondaAccordEX94
10-14-2010 03:59 AM
g22cd5
07-30-2009 08:15 PM
BuntinBoy9
11-11-2007 07:56 PM
importnewbie
08-16-2007 06:11 PM
