Keep Blowing Fuse #4 Small Lights Under Hood
I bought a small trailer to pull behind our Accord. Installed a wire harness from e-trailer. I keep blowing the tail lights. All the lights work untill I turn on the Headlamps. The total Amps for all the bulbs if all lights are on is 5.4 AMPS. Could this be too much additional load for the circuit. It is only 15 AMP. I don't know what is all connected to that circuit. I have checked the harness and trailer wiring for a direct short. All checked O.K.
Any suggestions?
Jim
Any suggestions?
Jim
Could be that the fuse is selected pretty close to the usage load? Then when you add the extra wattage of the trailer lights it goes over. Seems strange that it would be rated so close.
Check the fuse list in the owner's manual where it shows the amp ratings. If someone has installed a smaller fuse, then get one the proper size. I WOULD NOT get one any bigger than what's listed.
Uberpippi
02-01-2013 10:09 PM
alyssapie
08-13-2012 10:58 PM
