key light?
Old 03-27-2012 | 04:30 AM
leeschof's Avatar
Default ECU light
Originally Posted by PAhonda
Your key is working, so the imobilizer is working properly.
It flashes a few times on my car when I remove my key. I think that the owner's manual says something about the imobilizer light. It will probably describe the normal function of that light, then tell you to get the car serviced if the imobilizer light does something different.
Post back and let us know what you find in the owner's manual.
I have a 1998 accord (CG9) the ign barrel wore out so replaced the whole thing and the black box immobilizer too,the car now will not start with the green light flashing. does the ecu need resetting to the new key? as i thought the immobilizer box told the ecu the key was correct?
thanks
Old 03-27-2012 | 09:25 PM
The ecu and the key have to be programmed to "know each other". You'll need a locksmith with the proper tools or a dealership
Old 05-03-2012 | 07:43 PM
klrspz's Avatar
Sorry I dind't reply, I didn't have any notifications set up...
yes, it's working as desired, as I described in my other post.
*whew*
csh217
06-17-2014 06:53 PM
corlyf
09-13-2012 12:30 AM
AKcord
10-15-2006 08:43 PM
jrcastro
06-25-2006 01:03 PM
eckhart
05-08-2006 02:05 PM
