Keyfob Won't Lock Doors
Old 12-09-2012 | 08:24 PM
naicidrac's Avatar
Default Keyfob Won't Lock Doors
I have a 2006 Honda Accord 4 Door Sedan. I went outside earlier and noticed that my keyfob will not lock and beep the horn. The red LED flashes on the keyfob but it won't lock and arm the security system. I can unlock and open the trunk with the keyfob but cannot lock the car. I tried the spare keyfob and got the same results. Any Ideas? Thanks,
Old 12-10-2012 | 05:44 PM
It may be a problem with the Multiplex Integrated Control Unit (MICU), which is built into the under-dash fuse/relay box.
1. Do a battery cable reset by disconnecting the negative and positive cables and connecting them together with a jumper wire for 15 minutes. -- Do not touch the battery terminals.
2. If that doesn't work, the MICU may need replacement.
daver1100
05-30-2014 09:00 AM
Amtrak288
08-31-2011 09:18 PM
timbo114
05-20-2009 07:40 PM
galbak1
09-07-2006 01:26 PM
