knock sensor engine light still on after replacing
Start by initiating your own thread.
Is this a V6 or 4-cylinder?
Either you installed a faulty knock sensor or you have a wiring fault. To determine which you will need to disconnect at knock sensor and at ECM and check wiring for open or short on signal knock sensor wire or connector. It could be damaged wire or damaged connector at sensor.
