Lock cylinder swap??
Old 01-27-2011 | 12:50 AM
bigdawg74's Avatar
Default Lock cylinder swap??
The tumblers on the driver's door on my 91 are worn down and it's getting hard to lock/unlock the door. Gotta find the "sweet spot" for it to work. The passenger door works just fine. Can I just pop the door panels off and swap the lock cylinders? Will that screw up the power door locks?
Old 01-27-2011 | 01:25 AM
I for one am not thinking it will mess with your power locks...check with Honda if you get crazy about it.
Maybe one of the members might have done this already and can answer it for you..
Old 01-27-2011 | 01:48 AM
You should be able to do that. You'll have to take apart both doors to remove.
An easier option would be to have a locksmith replace the tumblers in the driver's door lock. See what someone would charge to do the work.
Chris Jameson
02-19-2013 07:39 AM
WallySparks
03-02-2012 07:24 PM
STINKA621
03-09-2009 08:53 AM
PJ_STYLES_95AccordEx
10-24-2007 10:58 PM
