Long Drive
Long Drive
Hi,
I have recently purchased a 2010 Honda accord which has already 1,15,000 miles on it.
I generally take long road trips and drive about 800-1000 miles in a stretch and around 2000 miles on round trip.
Will my car support long road trips without any problem ? Or should i just use for daily commute for the long run ?
And till what miles will it last without any problem ?
Suggestions and answeres highly welcomed and appreciated
Thank you.
Thank you.
There won't be any specific answers. It all depends too much on the condition of the car.
What engine and transmission? Honda Accords have been known to last easily a few hundred thousand miles.
But with ANY car, it's always possible that a previous owner has not done proper maintenance, or otherwise caused excessive wear. You won't know EVERYTHING that has been done with that car in the last 9 years. The thing to do before you buy a car is have a good mechanic check it out as a "buyer's inspection".
Finally, the "HAF Help" section is for questions about how the website works, not questions about the car. Each forum area has a sticky thread something like "everyone please read this" and it describes what the topic is all about. So I'm going to move this over to General Tech where more people will respond.
Welcome to HAF!
Welcome to HAF!
Welcome to HAF!
Welcome to HAF!
One notable issue with some; but, not all 8th generation Accords (both 4 and 6 cylinder) is excessive oil consumption. I believe that due to class action lawsuits, Honda extended the warranty related to that issue if it exist for certain VIN ranges.
So for long trips, I would recommend carrying an extra quart and check the oil level after each extended long one-way trip and top off if necessary.
You won't have any problem using your car for 2000 mile trips when you're starting at 115,000 miles.
My '92 has 270,000 and is still used for trips like yours.
Welcome to the forum!
nickmg555
12-22-2013 08:02 AM
