lost power in dash gauges and windows 96 honda accord
Old 09-04-2013 | 07:45 PM
bbybluluv87's Avatar
Default lost power in dash gauges and windows 96 honda accord
I have a 96 honda accord and a friend installed an after market cd player now im not getting any power to my dash the gauges wont move and the lights arent on and my wondows wont roll up or down please help any suggestions?!?!?
Old 09-04-2013 | 07:55 PM
Check Fuse No. 1 (10A) in the under-dash fuse/relay box.
Check Fuse No. 32 (15A) and Fuse No. 37 (7.5A) in the under-hood fuse/relay box.
Old 09-04-2013 | 08:17 PM
Thanks it kinda just worked its self out idk what happened
Old 09-05-2013 | 03:38 PM
ok so im guessing its a short somewhere cause it came on was working fine now its off again we checked all fuses they are fine and so are the relays i dont know much about cars but im guessing its a short somewhere
Old 09-05-2013 | 04:02 PM
If the fuses are okay, it may be an "open" somewhere in the circuits.
The following is Honda’s narrative regarding Opens and Shorts:
"Open" and "short" are common electrical terms. An open is a break in a wire or at a connection. A short is an accidental connection of a wire to ground or to another wire. In simple electronics, this usually means something won't work at all. With complex electronics (such as ECM/PCMs) this can sometimes mean something works, but not the way it's supposed to.
You may have an "open" where there is a break at a connection or wire.
Old 09-05-2013 | 04:30 PM
You may want to use a test light, voltmeter, etc. to see if there is power at the fuses.
Then check that the harness connectors at the under-dash fuse box are firmly in place. There are connectors on the front and back of the fuse box, it may be a connector in the back that is not fully seated.
georp
03-02-2015 09:10 AM
jdenny81
06-02-2012 06:28 PM
tipzjames
07-31-2007 11:21 PM
th22ek9
09-08-2006 10:07 PM
