lost pressure in the pedal when applying brakes.
Old 04-25-2011 | 07:32 PM
planeteclipse's Avatar
Default lost pressure in the pedal when applying brakes.
Its a 1989 honda accord lxi. I replaced the front brakes about a year ago. Just checked the back drum brakes and the pads are good. Fluid is still at full reading. Im at a loss as to what to do now. Should I bleed them next or is there something I need to look at?
Old 04-25-2011 | 08:12 PM
crispin's Avatar
Master Cylinder most likely.
Old 04-25-2011 | 10:00 PM
As stated,, master cyl is at the top of the list. While the car is running, apply pressure to the pedal and hold...does it seem to sink?
Old 04-26-2011 | 06:19 PM
The classic description of air in the brake system goes like this:
Pedal is very soft and goes way too far down. If you pump the pedal it becomes OK.
The classic description of a bad master cylinder goes like this:
Pedal feels normal when you first apply the brakes. As you hold the brakes (say at a red light) the pedal sinks slowly & smoothly to the floor.
Tocramed
01-08-2013 08:58 AM
Luckyluciano
08-04-2012 03:18 PM
Derek Sithol
01-19-2010 01:37 AM
stephen94accord
08-21-2009 10:58 PM
19Accord97
07-19-2007 08:42 PM
