loud noise when accelerating
Old 10-29-2008 | 11:26 AM
Tippman7641's Avatar
Default RE: loud noise when accelerating
the cai will whistle if its drawing to much ari or is to large for your motor, mine dose it to, almost sounds like a turbo whine sometimes
  #22
Old 10-29-2008 | 08:21 PM
stevenb17
i dont know to sound like a jerk or anything becuase i appreciate your guys' help but this was happening BEFORE i put in my intake and only at a certain rpm so i don;'t think it's the sound of the intake. whistling was a bad description. chirp would be a better word for it.
  #23
Old 10-29-2008 | 08:24 PM
how many miles?
  #24
Old 10-30-2008 | 09:41 AM
falkore24's Avatar
Verify that you have all of your fluids, check and rule out what has been suggested, then post back.
  #25
Old 10-30-2008 | 09:48 AM
perhaps one night when you were asleep someone broke into your car and installed a turbo charger? that would give it quite the whistling noise.
maybe a video of said noise would help us diagnose it
  #26
Old 11-03-2008 | 06:25 PM
stevenb17
i just got my transmission fluid and oil changed and everything checked so that's not it. i tried to take a video on my phone but you couldnt here it when i tried to play it. it's not a noise from a belt where it's more on a beat it's a constant noise that doesnt stop unless i change the rpm's.
and to tippman- it has about 96,000 on it.
  #27
Old 11-04-2008 | 08:42 AM
falkore24's Avatar
Does -everything checked- include power steering fluid? Coolant? Make a checklist with ALL of the recommendations and go through each and every one to rule it out.
  #28
Old 11-26-2008 | 01:10 PM
Hobbin's Avatar
ORIGINAL: falkore24
I KEEP FORGETTING TO COME BACK AND REPORT
So earlier falkore said something about the noise being from the power steering pump. It reminded me that my power steering fluid was a little below the threshold.
This was my problem.
That crazy squealing (that only happened in drive when I wasn't moving) was due to a low power steering fluid.
I felt like such an idiot for not eliminating that as a possibility in the first place!
  #29
Old 05-02-2009 | 10:06 PM
jbrown101
StevenB17: did you figure out the cause of the squeal?
I just bought an older Accord and it makes the same squeal noise when the gas pedal is at the right point during acceleration. I've ruled out the air intake and belts. Not sure what else it could be.
RedskinsOne
11-20-2018 12:23 AM
Ferius
04-28-2011 01:08 AM
botang47
10-15-2008 08:02 AM
cyberbob
01-03-2008 12:27 PM
garyg791
01-08-2007 09:43 PM
