Loud Rattle On Cold Start Up & While Driving
Old 11-19-2013 | 12:53 PM
This video from youtube may help. Pretty easy to implement.
Old 11-19-2013 | 05:26 PM
bsdubois's Avatar
Default Clicking/Tapping Noise was not VRC acutator-- bad rocker arm
I stumbled on this YouTube video by accident. This video was posted on YouTube by Jerryteck. I thought of the issues you are experiencing and decided to copy the link for your ready reference. (I hope I did not make another mistake and violate the term of use. I am new to the forum and need to read all this ins and outs. I apologize in advance if I made another error.)
The vehicle in the video is a 2011 Accord with clicking/tapping noise. Several times to the dealership and they eventually preformed the recall (please review text following the video). It helped until the next time the vehicle was cold and the engine was started. The Dealership eventually found the cause of the clicking/tapping. The engine had a defective rocker arm! You might watch the video and compare it to the sounds coming from you 2009 Accord.
I hope this helps!
Best of luck.
Old 11-19-2013 | 11:00 PM
Goldwinger's Avatar
Dropped the Accord off tonight, and I will let you guys know what happens with it.
Thanks all.
Old 11-20-2013 | 09:11 PM
Goldwinger's Avatar
bsdubois, I had about 6200 miles between oil changes, no oil leakage that I could see.
I dropped the accord off last night and showed them the video. They called me this morning and said that they had already changed the VTC Actuator, and had to check out the cam chain and timing belt, to see if they were bad. Then they called me back about 2:00 and said that it was done. (The only thing they changed was the VTC Actuator.) I just picked it up and brought it home and everything seems fine. The noise always happened in the morning on cold start ups, so I will see tomorrow morning.
Thanks for all of the input everybody.
Old 11-20-2013 | 09:14 PM
Goldwinger's Avatar
Thanks for the video Brian, I appreciate it.
Old 11-20-2013 | 09:17 PM
Glad they fixed it. There is no timing belt. The cam chain is the timing chain.
  #17
Old 11-21-2013 | 06:41 PM
bsdubois's Avatar
Default Glad they fixed it.
Goldwinger:
You are very welcome. You have a follow-up video in the event it is not completely repaired. I am glad your Honda Dealer finally listened to you and fixed the issue. I hope it is completely fixed and it is working correctly in the morning when it is started cold. Please drop a note after the am cold start.
Good luck with the Accord in the future.
  #18
Old 11-23-2013 | 11:26 PM
Goldwinger's Avatar
Ok so I started up the Accord this morning, ready to hear the loud metallic sound, and nothing but the car starting. Fantastic! It's fixed. Now if I could only get the surging fixed...
  #19
Old 11-24-2013 | 12:36 AM
Glad to see you have that problem fixed, now on to the next problem.
  #20
Old 11-24-2013 | 03:59 PM
bsdubois's Avatar
Default Accord Surging
Goldwinger, will please start a new thread on the surging and explain what the vehicle is doing, what speeds, what gear, hot, cold, etc.
Glad to see they fixed you service bulletin issue.
Good luck.
Cubbie
04-13-2014 02:26 PM
cdarnt
02-23-2011 09:15 PM
sjm5104
07-03-2009 06:27 AM
HondaAccord93
03-18-2009 09:40 PM
sbutler
04-23-2008 12:46 PM
