Low oil pressure @ idle - 93 Accord
RE: Low oil pressure @ idle - 93 Accord
ORIGINAL: PAhonda
Is the oil light coming on with the new sensor installed?
On a related note - what would cause the light to flash regularly? The flickering led me to believe it was just a direct connection between the sensor and the lamp - but that wouldn't account for the regular flashing, which would indicate some electronics in between.
Is this vehicle OBD2? Likely to have a code available even though the CEL hasn't come on?
edit - nevermind. Just found something indicating that Accords didn't get OBD2 until 96
Based on the fact that it doesn't come on until its at running temperature, it would almost lead me to believe that you have a gasket or hosethat's just gotten dried out. Once the engine heats up, the gaskets and hoses will expand slightly and allow the pressure to be released. But it seems like, you'd be leaking more oil if that was the case.
I couldn't recall what the PCV configuration was on the 93.... I know that a lot of the carb models dump the PCV straight into the air cleaner box so I mentioned it just because I haven't dug around under the hood's of a 93 very much....
How long has it been since you've had an oil change?
I'll throw this out there and see what others think but possibly a failing or clogged oil pump?
Ok, got an oil & filter change on the way home. 10w30 vs. the 5w30 it was running. No significant difference in the light - came on again as soon as things got good and hot.
I think the flashing thing starts after the oil light comes on steady, even if the pressure is currently ok. If I turn off the engine, then start it again immediately, and keep the RPMs up, no flashing light. If I let the RPMs drop again to where the light comes on, the light flashes when I spin it up again.
Will try swapping the pressure switch tomorrow. And there was no oil in the air filter box.
Thanks guys
Thanks guys
The oil pressure switch closes at a very low pressure, 3.6 psi on 90 Accord and yours is probably same. If light is coming on and pressure is truly low, you should hear some clattering valves and perhaps connecting rod knock. If the new pressure switch doesn't resolve the problem (likely IMO), you'll need to pull the oil pan and check the oil pump intake for blockage.
The CEL may be illuminated whenever the oil pressure light is on for a certain period. A flashing CEL is a warning to do something, and not defer service.
ORIGINAL: TexasHonda
ORIGINAL: sir_nasty
Have you had a chance to change that pressure switch yet?
