Low rumble from rear of car...wheel stops during spin test
Old 04-01-2010 | 08:51 PM
JohnnyBoy's Avatar
Default Low rumble from rear of car...wheel stops during spin test
1996 Honda Accord LX with 37,000 miles :
So I started noticing a low frequency sound coming from the rear when I was at low speeds, between 10-20mph. It sounds sort of like an intermittent grinding sound, and depends on how fast the wheels are spinning. At higher speeds, the sound eventually becomes un-noticable.
I was really careful in my listening today, and I'm sure it's coming from the rear of the car, which is a good thing, because all of the expensive and complicated parts on this car appears to be in the front. The rear wheels are just a hub, a bearing, and a brake drum.
I jacked it up, and found that while the left rear wheel spins freely, the right rear one makes an intermittent sound as it turns and quickly comes to a stop. I'm a guessing that this is the culprit.
It doesn't sound like bearings to me, it sounds like the brake system is rubbing. Should I attempt to fix this myself, or just bend over and take it to a brake shop? I've never worked on a car before.
Old 04-02-2010 | 05:00 PM
deserthonda's Avatar
pull the drum off, see if anything is out of place, maybe a spring ?? shoes hanging up ??
Old 04-02-2010 | 10:42 PM
ROFLmao's Avatar
if not any brake issues than it might in fact be a bearing on it's way out. My 626 had that nice rumbly noise as well.
scjfly
06-29-2011 02:48 PM
Hondalover
03-15-2011 07:09 PM
Fizgig
05-04-2010 08:37 AM
satchmo
01-21-2008 01:49 PM
o4vroom
12-23-2005 05:09 PM
