Lower ball joint problems...
Old 02-15-2010 | 06:47 PM
Diagram14's Avatar
Default Lower ball joint problems...
I am about to have to replace my front drivers side lower ball joint for the third time in a year. I was wondering if there is another front suspension issue the could be causing the ball joint to go out early. Or am I just being plagued by a poorly designed product?
Old 02-15-2010 | 07:03 PM
What is wrong with the ball joint? Is the ball joint loose? Is it making some kind of noise?
How are you installing the new ball joints?
Old 02-17-2010 | 12:14 AM
Diagram14's Avatar
They start to squeak and get progressively worse. When I pull them off and move the joint around by hand it feels as if its grinding. As far as the install goes, I pull the entire steering knuckle and have both pressed a joint in and tapped one in with a dead-blow hammer. There was no real difference in longevity from one to the next. About 4000 miles.
Old 02-17-2010 | 12:20 PM
Any chance the rubber boot is opening up & dirt getting as you re-install the knuckle? IIRC, the rubber boot is long & when you put the tapered stud into the hole in the knuckle, it pushes it back a couple mm. Make sure everything is very clean.
Old 02-17-2010 | 12:41 PM
kris_loehr's Avatar
What brand joint did you? Do they have zerk fittings or a plug for one.
Old 02-17-2010 | 01:27 PM
deserthonda's Avatar
is car stock??any suspension modifications ?? factory ball joints ??
those things should last a very long time
Old 02-17-2010 | 05:20 PM
kris_loehr's Avatar
"When I pull them off and move the joint around by hand it feels as if its grinding."
Could this be the way they are new for the brand you purchased? I have seen people use a sledge hammer to install a pressed in ball joint and even dented up work fine. It takes a lot to have a problem. Could it be something else is making the noise?
Old 02-17-2010 | 06:33 PM
The only thing that would screw up a ball joint (other than an incorrect installation) is another suspension component is worn out.
Check the lower control arm bushings, tie-rod (inner and outer), upper control arm bushings/ball joint, radius rod bushings, anti-sway bar end-links. Am I forgetting anything else?
A crappy part could also be the problem. I remember that the OEM ones from the Honda dealership are pretty cheap, around $20-$25.
Old 02-17-2010 | 10:16 PM
kris_loehr's Avatar
But the OP isn't saying the joints are worn just that they squeak.
Old 02-18-2010 | 08:47 PM
Diagram14's Avatar
I admitt that the joints are the $16 Oreilly's special. The installations have been clean and as far as I can tell correct (properly seated). The car is stock. Moving the new and old joints around in comparison, the feel is completely different. The bad joint has a gritty feel to it, which I do not understand considering the cleanliness of the install. Concerning the other suspension components being worn out, is there one over another that would be a greater potential cause?
