Lower Control Arm Replacement
Old 05-15-2013 | 09:58 PM
RobinsonRicer's Avatar
Question Lower Control Arm Replacement
So if you saw in my other post this is my best option. Im getting the new part and noticed a few things that confused me about the replacement. In the haynes manual it says that you remove the front lower control arm in 3 locations. Im starting to see why that manual sucks. The FSM shows a bit more but doesnt explain it. I see two more bolts on top.
Can I replace this without any special tools to compress the spring or anything that may come lose and not go back together so easily or is this pretty straight forward?
thanks
Attached Thumbnails Lower Control Arm Replacement-previewofldquohondaaccordcoupe1994-1997servicemanualpdfrdquo_zps9cd102cb.jpg
Old 05-16-2013 | 03:51 AM
TerryB's Avatar
The 2 on top are the front sway bar bolts. Pblast them before starting.
Old 05-16-2013 | 09:02 AM
Ok. Thanks
cyberhiker
11-01-2016 11:32 AM
JohnNH
01-01-2015 04:32 PM
Colondo
01-25-2013 10:58 AM
Steve93
10-19-2007 06:02 AM
RoKnAzn
05-21-2007 07:29 PM
