Lunging on acceleration/deceleration & slight vibration
99 Accord 5-speed which I just bought 3 days ago. Noticed under acceleration and decelerating a lunging, almost as if it needed the fuel injection cleaned badly.
Also, while on the highway where it's most noticeable, a slight vibration which I feel about every 5 seconds, consistently. And it's very subtle, not terribly noticeable, but I can feel it.
Also, the check engine light is on, haven't run the codes though.
My untrained mechanical ideas are maybe motor mounts??
Grab the valve cover & shake it to check the engine mounts. Loose mounts won't set off the CEL.
Has it been sitting in a driveway with a forsale sign for very long? Stale gas? Or maybe gas that's NOT winter-blend? If you're lucky it might get better when you use the gas & refill.
P1457 = EVAP system leak; in the canister section of the EVAP system
That "shouldn't" do anything that you can feel. There's a thread about it over in the DIY section.
However... If you're in the habit of over-filling the gas tank, the charcoal in that EVAP canister might get saturated. Then that might cause both the lunging and the P1457.
frmrpriownr
11-15-2011 10:50 AM
RandyJW
11-12-2011 11:23 PM
