maintenance required red what do i need to check?
Old 01-14-2011 | 10:57 PM
handro0329's Avatar
Post maintenance required red what do i need to check?
I have a 95 honda accord DX MT and the maintenance required has turned red and I do not know what else to check
Old 01-14-2011 | 11:07 PM
This is usually for an oil change....when was that done last? If needed then have it changed and re-set the reminder....but I have to ask what do you know about the other items, how many miles and what has been done?
Old 01-14-2011 | 11:39 PM
Default Hello New Member
Check out the oil change yet?
Welcome to the HAF...
Old 01-14-2011 | 11:47 PM
handro0329's Avatar
i did the oil change about 500 miles ago, the car has about 145000 on it and everything that i know of has been maintained but i am gonna do a timing belt replacement because i do not kno the last time that was changed. does that red light have to be reset after the oil change?
Old 01-15-2011 | 10:31 AM
"does that red light have to be reset after the oil change? " Yes (kind of), again it is just a reminder for oil changes that goes off milage. So it doesn't really hurt anything...it just bugs me so I always re-set mine. To re-set just inset/push the key into the little slot. It will then go back to green.
Old 01-20-2011 | 01:04 AM
handro0329's Avatar
hey thanks i reset it and now its green again. the red light def bugged me because ive done everything but didnt kno i had to reset the light, such a simple fix
818coupe
07-23-2019 03:36 PM
azdrake
11-04-2013 08:03 AM
emgomez
06-21-2008 02:48 AM
Daveyjones
05-30-2006 11:17 AM
hotrod01
11-11-2005 02:28 AM
