Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
Old 07-24-2009 | 02:24 PM
piconrule
Default Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
I have a 2002 Honda Accord LX. Engine light went on so i plugged in my obdii and scanned it.
Got the result Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
engines seems to run poorly and stalled once.
Anyone know where the location of the MAP sensor is? or other ideas on how to fix it??
thanks alot
Old 07-24-2009 | 03:00 PM
Suggest going to Autozone.com and look up diagnostic repair info on barometric pressure sensor. It is likely the sensor is faulty, but wiring or connector could also cause this problem.
Old 07-24-2009 | 03:38 PM
Check the wiring like Tex says.
On a 4-cyl, the MAP sensor is on top of the throttle body #11. LX could have a V-6 engine, but you didn't say...
I'm not sure, but I think the Baro sensor is built into the ECU (not true for ALL years).
But in the Honda world, those 2 sensors don't share the same OBD-2 error code. Too bad you don't have the actual code number.
Becker
02-26-2019 12:15 PM
eduard
05-09-2013 01:11 AM
HondaAccordNewb
10-18-2007 07:51 AM
hawaiian5
05-30-2007 07:14 PM
no_doz
06-17-2006 12:28 PM
Quick Reply: Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
