Manual Shifter Reverse Lockout
Old 10-26-2007 | 06:11 PM
kbunting
Default Manual Shifter Reverse Lockout
My son has 2000 Accord ULEV 4 door sedan EX model with 5 speed manual transmission and 4 cylinder motor.
Last night he could not get reverse but all forward gears work fine and shift smoothly.
Honda told him this was common with Accords and that there is likely a burr on the reverse lockout mechanism of the shifter.
Has anyone experienced this and can a do it yourselfer fix this at home?
I restored my Corvette but have never worked on his Honda.
Hethinks the shift mechanism can be removed from the transmission without removing the motor and transmission from the car.
Any suggestions on what th eproblem is here and how to fix it without getting the dealer involved?
Thank you in advance,
Kurt
Old 10-27-2007 | 09:25 AM
kbunting
Default RE: Manual Shifter Reverse Lockout
Anybody here????
Old 10-27-2007 | 11:31 AM
smaglik's Avatar
weekends are slower times on this board...apparently most people do this when they should be working...just be patient.
Old 10-27-2007 | 07:56 PM
Chiovnidca's Avatar
ORIGINAL: kbunting
I've never heard of that. Sometimes the gears dont line up right and you have to put it in another gear first to help line em up. Or let the car roll a little.
Old 10-29-2007 | 12:37 PM
00AccordLX5spd's Avatar
Registered User
Have you tried letting the clutch out a little bit to enable it to go into reverse - sometimes mine doesn't want to go into reverse and I have to do this. Also try shifting to 5th (stopped) then pull it down into reverse with the clutch still depressed.
Cheeva316
10-19-2011 07:33 PM
Max Utility
05-19-2011 01:32 AM
saanich
09-29-2009 03:41 AM
etodak
08-03-2008 08:37 PM
twoaudio
06-10-2008 08:45 PM
