measuring trans. level properly
RE: measuring trans. level properly
SOME dipsticks have a cold and hot level mark but due to the variance in expansion and various cavities that need to be filled it's generally not a good idea to check it before it's warm.
So, you can check it on some vehicles but it's still better to check it when it's warm.
Thanks for your reply.
A reason for asking is that the level on the D.S. varies from one warm check reading to another. As a example, one time it will read to the "add" mark,the next time it will read "full".
Just concerns me that the readings are never consistent like engine oil.
make sure the car is level and at full operating temerature, then shift through the gears, stopping at each gear for a second with your foot on the brake, throw it into park and do your normal check. if you follow that procedure and the car is lvl it should always read the same. Or at least close to the same. Also, be sure you're pushing the dipstick all the way in.
ORIGINAL: sir_nasty
ORIGINAL: daswede
You wouldn't think a grown man would have have so much trouble checking the oil.
GL!
I usually check the trans. "Cold" for no special reason. In doing so,i find the level varies from below the "add" mark to almost the "full" mark.
All conditions being the same in checking this way,i have to ask why the level changes from day to day under the same checking procedures?
I don't see any evidence of a leak. The fluid is nice and pink which i would it to be after only 10 k on the odo.
ORIGINAL: sir_nasty
make sure the car is level and at full operating temerature, then shift through the gears, stopping at each gear for a second with your foot on the brake, throw it into park, TURN THE ENGINE OFF,and do your normal check. if you follow that procedure and the car is lvl it should always read the same. Or at least close to the same. Also, be sure you're pushing the dipstick all the way in.
