MOTOR SWAP
MOTOR SWAP
swaping my 97 motor (blown) with a 96. same model and all just diff years. it should work right? only difference i can see is the coil (or whatever its called where ur spark plugs go) on the 97 the main one 5th has a hole for it on the coil on the 96 i dont see the hole. cant find where it goes. help
RE: MOTOR SWAP
I didn't bother looking up which years were internal or external. Just took his word for it...
Besides, if you use your existing ECU & wiring harness, then using the matching distributor would make some sense anyway.
Doublel
03-11-2013 07:57 AM
