motor swap harness question
Not sure about this, but did you swap the ECU? Vaguely remember something about the VSS being different for auto vs. manual. I think there's a rev-limiter active when there's no signal from the VSS, just so you can't over-rev when the car isn't moving.
Have you checked for engine codes?
Did you verify the injector resistor bank is plugged into the correct connector?
You may be better off using the original harness that was in your car, because it would eliminate one of the variables that can cause a problem.
Were both engines the same trim level (i.e,: LX)?
This is more detail to add to some of what already was said by poorman212 and PAHonda:
Engine Harness ((L4) (DX, LX, Canada EX)
Connector Number of Cavities/Color Location Connects to Notes
C118 1-BLK Middle of engine Back-up light switch (+) M/T
C119 1-BLK Middle of engine Back-up light switch (–) M/T
C120 2-GRY Middle of engine Countershaft speed sensor A/T
C121 2-GRN Middle of engine Mainshaft speed sensor A/T
C122 3-GRY Middle of engine Shift control solenoid valve A/T
C123 2-GRY Middle of engine Lock-up control solenoid valve A/T
C128 6-GRY Right side of engine compartment Main wire harness A/T
Hey Redbull. Sorry about my very delayed reply, as I somehow missed your post and got distracted on my 'other thread, (no ecu light, no rev over 2800 rpms), which eventually became merged information. I will only be continuing on That thread as to Not cause any more possible confusion, lol. But, Will post my ultimate, total repair findings here once completed. Thank you much !
Everything is fixed and working correctly! Firstly, yes, you CAN swap a 1996 accord 2.2 motor from an automatic with it's harness into a same year, (I think a 1997 too), directly into a 5-spd. There will be a few extra unused connectors that can be taped off and stowed. The 'no rpms over 2800' ultimately was a bad Crank Sensor, which would not produce codes, initially. The 'no CEL light was do to a 'missing' bulb.
Thank you again!
Peace, Abundance and Joy,
Hondaddy
Thank you again!
Hondaddy
Mario Locatelli
09-17-2013 10:53 AM
