My Accord stays on without key and more problems Need Help
Old 03-26-2012 | 05:52 PM
PrettiBoiHonda's Avatar
Default My Accord stays on without key and more problems Need Help
So I have a 1998 Honda Accord EX V6. When I turn off the car all the lights in the Dash are on without the key and sometimes the car stays on without the key. The only way I can turn off the car is by pressing the brakes. Don't know what exactly it can be. Also the doors and the battery light in the dash will flash when rolling the windows up or down. Need some help.
Old 03-27-2012 | 07:30 PM
When this happens, check th BLK/YEL wire to the dist for voltage.
Are the tune up items (cap. rotor, wires, plugs, ect) up to date?
Old 03-27-2012 | 10:24 PM
Do you have a security/alarm system installed on the car?
Old 03-28-2012 | 12:15 PM
It has the factory alarm system.
Old 03-28-2012 | 01:05 PM
This has appearance of ignition switch assy failure. Contacts may be welded together or sticking together. It could also be a failure of key/lock assy which engages the ignition switch assy (not fully coupled somehow).
Ignition switch replacement is easy job, < 1 hr for first timer w/ some experience. Shop should do for 1 hr labor at most.
Old 03-28-2012 | 09:14 PM
Yep, that is why I asked about power still going to the dist thru the BLK/YEL wire.....a quick test should confirm.
Old 03-28-2012 | 11:39 PM
Sorry, I meant to ask if you have a remote starter installed on your car?
csh217
06-17-2014 06:53 PM
pvenuti
11-19-2013 08:34 PM
Tex_hooper
09-23-2013 07:43 PM
Itstheaccord
10-11-2012 09:03 AM
thunder_x
08-18-2006 03:48 AM
