My daughter's car. 2000 Accord MIL lit
RE: My daughters car. 2000 Accord MIL lit
Voltage looks good. Check voltage across the ECU input may not tell you anything.
Did you check the resistance of the new O2 sensor. Since you have voltage, you should confirm that O2 sensor resistance is in spec.
I don't think the O2 sensor would be significantly different on the two models, but some vehicles, starting about 2000, used air/fuel ratio sensor, a more sophisticated air/fuel mixture sensor. Make sure your car does not require such a sensor. It usually has more than 4 wires, so probably not.
Remember the code is for the O2 sensor heater, so that circuit is being sensed to have an open or short somewhere.
ORIGINAL: TexasHonda
UPDATE: I went through troubleshooting procedures and was getting to the point to where I was sure I had a bad PCM. I put everything back together one last time & the code was cleared! All I can figure is that there was a bit of oxidation on one of the connector pins at the PCM and disconnecting and reconnecting the connectors must have "wiped" the oxidation off. Thanks everyone for the help!
Bexar
06-19-2011 07:10 PM
