is my rad shot? (new inst. questions inside)
Old 01-23-2008 | 08:53 AM
reinventingaxlrose's Avatar
Default RE: is my rad shot?
not sure if it's anti freeze or not. looks a little thick to be... i just picked up the rad already removed from the old vehicle and there was/is some of this stuff sitting in one of the bottom hoses. they just chopped the hoses when they removed the rad from the car. i'm going to clean it out before installing it anyway. i'm going to start the installation process in an hour or so. hopefully all goes well and I don't need any more parts as i'm in the middle of nowhere right now.i'll be back if i have any more questions :P thanks guys.
  #22
Old 01-23-2008 | 10:15 AM
falkore24's Avatar
Since you're in the middle of nowhere and you need an immediate fix, just stuff some paper toweling or a small piece of a rag in the tranny cooler lines. It should look like a single strip of baseboard, like what's inside the casing in a home. kinda like this:
  #23
Old 01-23-2008 | 03:43 PM
my old rad had caps to cover the two tranny lines. new problem though. stupid one. can't find the bleeder bolt?! i have the shop manual and the picture isn't much help at all...
  #24
Old 01-25-2008 | 10:36 AM
falkore24's Avatar
Don't you just run it for a while with the radiator cap off???
  #25
Old 01-25-2008 | 12:51 PM
The bleeder bolt is #13 on top of the thermostat housing.
  #26
Old 01-25-2008 | 02:29 PM
sir_nasty's Avatar
ORIGINAL: reinventingaxlrose
Not sure if this is the issue or not but I've seen where someone has taken that radiator stop leak and put it into the radiator which causes the fluid to change color slightly....
1994-Texas-LX
08-29-2013 11:05 PM
ibettysman35773
07-06-2013 08:14 AM
royzell
09-01-2009 01:47 PM
piffmiester2006
06-04-2007 11:49 AM
72mustang
02-12-2006 11:16 PM
Quick Reply: is my rad shot? (new inst. questions inside)
