My steering is really stiff
You should try to locate the source of the leak. It could be the pump, hoses, the connections, or the power steering rack.
Just follow the hoses to find a sign of leakage. There is a rubber boot at both ends of the steering rack. See if those are filled with PS fluid.
If it were a hose leaking, you would see a loss of fluid FAST. Pop the hood and have an assistant turn the wheels back and forth (with the engine running of course) while you attempt to see the leak. if it is a hose, it will spray fluid everywhere. Try not to get any fluid in your eyes.
Locate the leak source and we may be able to help you more.
