navagation system 2005 honda accord
Old 02-15-2015 | 05:52 PM
droopsss62's Avatar
Default navagation system 2005 honda accord
Navagation display not coming on, black screen.
checked ign power and unswitched power to dispay and dvd unit in trunk.
both had 12 volts on wh/red &yel/red wires . Which unit do I need to take out?
Old 02-16-2015 | 06:02 PM
droopsss62's Avatar
Default 2005 accord navagation help.
Here is a more detail on my previous post on the Sunday, on the black screen issue. On the display , all the non screen controls are working, radio, CD, temp controls etc. Like I said earlier, I have ign voltage and battery voltage on display and cd player in trunk.
Here are a few things I have tried. I've cleaned org. Disk and ejected its and reloaded it several times. I have disconnected battery for a few hours to reset every thing. I noticed you can't hear the unit in trunk doing anything when I load disk and shut the door. I would think you should be able to hear something. The only other thing I havn't done is clean the laser eye in the dvd unit. Is there any thing else I can try?
Old 02-17-2015 | 06:29 AM
Turtlehead's Avatar
You should run the system diagnostics and see if it comes up with an error code which you can then further investigate.
Yanivsme
05-15-2013 09:20 AM
gadawg31
09-23-2012 10:02 AM
Wylecyot
04-25-2011 09:51 PM
road warrior
04-01-2008 02:12 AM
