Need a fuel pressure adapter - where?
Old 03-08-2007 | 07:24 PM
cheggie's Avatar
Default Need a fuel pressure adapter - where?
I need to test the fuel pressure for my 91 Accord LX 5-spd, but I need an adapter for my fuel pressure gauge. I have 1/8" NPT male coming from the gauge, and I need to know where to plumb into the fuel rail/lines. Is there a commonly available part to adapt the rail to a ****** fitting or 1/8" NPT?
Old 03-08-2007 | 11:09 PM
Default RE: Need a fuel pressure adapter - where?
This requires a special banjo bolt adapter that I have not been able to find either. Haynes has a description in Accord manuals of how to make an adapter, but the procedure would require either a drill press or some very good nerves to drill a small hole longitudinally through a 1" bolt length. I've tried that before and it's not easy. The bolt is 12mm diameter x 1.25mm thread pitch, if you're game.
Honda apparently specializes in creating pressure ports that require unavailable adapters. Their transmissions have similar unavailable pressure adapter fittings.
Post if you find a suitable fitting.
basket_case
06-15-2013 10:56 AM
eduard
05-09-2013 01:11 AM
RobinsonRicer
03-20-2013 08:33 AM
BigOBob
01-01-2012 03:47 PM
piconrule
07-24-2009 03:38 PM
