Need help with 1998 Accord EX with DTC P1382
Honda Accord 1998,EX,4cyl, 2.3L,VTec,AT,F23A1
Hi friends,
I need your help. The DTC P1382 is driving me crazy!
After replacing my dizzy with a new one because the old one was leaking oil and the car was runing erratically, the CEL came on with P1382. When installing back the old one, P1382 comes back.
What I have done so far:
-Checked the timing and it is OK
-Measured the resistance between CYPP and CYPM on the male side plug of the dizzy and it measures 847 Ohms
-Checked for continuity between body ground and dizzy there is no continuity
-Measured resistance between PCM connector terminals the black and yellow wires. 847 Ohms
-Checked for continuity between body ground and PCM connector terminal (CYPP yellow wire). No Continuity.
-Changed spark plug wires
Can someone tell me what else to check or do I have to suspect the PCM or can it still has something to do with the timing or something else?
Hi friends,
RedBoneVirgo85420
04-13-2015 02:05 PM
