Need help finding parts for driver side window
1990 Honda Accord DX, 2.2 L, Manual
I was trying to fix my driver side window so it would roll up properly. But tightened the bolt that bolts to one of the two window clips at bottom of window and broke the bolt. So now I was wondering if there was a way to remove the window clip (for lack of the proper word) that the metal bar bolts on two? I couldn't remove the bolt when with an extractor because that broke off too. I am thinking if I can't remove the clip at bottom edge of window I guess I should use some really strong glue to glue the metal bar that bolts to it.
Also, I wanted to know if anyone knows if I can buy the rollers that go on the window regulator tracks, instead of having to try to find them from a salvage yard or buying the whole window regulator?
Thanks!
Thanks!
Yes, I have a four door (manual regulator). The bolt #21 broke off and then when I tried to use an extractor that broke too. So it was too hard of metal for me to drill into to try and extract the extractor (Which broke off in the hole I drilled in bolt #21). I really hope I can just remove the clip that the bolt bolts onto and replace with a new one and new bolt.
And I noticed that I am missing a roller and the other roller in the track is broken. Looking to see if I can buy those from some place online instead of going through Honda dealership in town.
It doesn't look like the Honda Dealership sells the rollers. Also, the clips on the window do not have a part number, so you may have to get the window too.
If the rollers are replaceable, then search around for aftermarket sources. You may have to get the glass at a junkyard.
David Crevenston
09-27-2010 07:04 PM
David Crevenston
09-26-2010 12:49 PM
MountainManBeard
06-26-2010 01:26 AM
Buktheng
12-06-2007 05:49 PM
