Need Help with P1457 code
I went to autozone and check the check engine light. It said its a P1457 code. It said possible loose gas cap, purge seniold sensor. Does anyone has the same issue that knows how to fix? I searched this forum and people are saying different things. Thanks
RE: Need Help with P1457 code
the only things that i have personaly go bad are
the evap 2 way valve and the evap bypass solenopid valve
Both located at rear of car by the fuel tank.driver side area,
gas cap has nothing to do with that code though. you need to manually energize each evap solenoid and verify they are clicking. if one is not clicking replace it and cross yoru fingers. if all are clicking you need to start vacuum testing(urgh...)
Just an update. I replaced the EVAP control canister on my 98 and the CEL did not go on for 3 weeks now. Thanks to the forum and the Honda Service Bulletin I found on this forum.
Yessy Consuegra
01-18-2014 09:21 PM
