need some advice! driving car 1000 miles
#21
The lock-up feels a bit like the transmission is shifting, but it's a lot weaker than an actual shift.
Right about the ATF - you can only drain about 1/3 of the total fluid each time.
Get down in front of the right-front tire, looking under the car, towards the centerline of the car. The transmission drain plug has a square hole that accepts a 3/8 socket extension without any socket. Re-fill through the dipstick hole.
Honda ATF (not Dexron or not generic) a bit less than 3 quarts per drain/fill. After filling, check dipstick level with the car all warmed up but turned OFF. That's different than most other car companies who want you to check with the engine idling.
#22
Yeah, but judge the real need by how dirty the fluid comes out. I can't see it from here... For all I know it's so dirty you'll need 4x or 5x. Or not.
Drive around inbetween, even going a week or 2 inbetween. I'd go far more than just around the block.
The 3x changes are a pain, so once it's clean, it's best to establish an ATF-change interval that doesn't allow it to get real dirty anyway.
bellend
11-01-2013 06:23 PM
freshjiv
09-24-2012 02:42 PM
