Negatives of using GM synchromesh in h22 accord
Old 10-28-2008 | 09:40 AM
thewraith's Avatar
Default Negatives of using GM synchromesh in h22 accord
Hi all,
I have a 95 ex w/h22 swap. My car grinds gears and in the past I have used synchromesh in all my cars. I know honda's typically use regular motor oil in place of gear oil. Will using synchromesh cause me problems?
Old 10-28-2008 | 10:33 AM
Default RE: Negatives of using GM synchromesh in h22 accord
i ran royal purple syncro whatever in mine, didnt help, ran honda mtf, didnt help. let me guess, 5th gear grinds
Old 10-28-2008 | 11:03 AM
thewraith's Avatar
Yeah
I guess I'd have to just double clutch, get my synchros replaced, or perhaps adjust my shifter cables?? It also sometimes comes out of 3rd gear.
Old 10-28-2008 | 11:04 AM
yeah prob wont help, welcome to the club
Old 10-28-2008 | 11:05 AM
thewraith's Avatar
Which foglights are those? They look hot. Thanks for the advice as always bro.
Old 10-28-2008 | 11:13 AM
stock ones
Old 10-28-2008 | 10:43 PM
madsteez's Avatar
I would go with the Pennzoil syncromesh,its designed for brass,copper, and bronze transmission parts. All which is typically found in Honda transmission.
Be aware,you most likely would notice a difference and your most likely grinding due to a bad hub/slider.They get more wear and tear that Syncros and are prone to give out earlier. Trust me,my 2nd gear hub went out within a week of replacing it with a brand new oem one. The 3rd gear slider also started to give before I sold the car.
spin05
09-23-2021 08:10 AM
kayweb
02-07-2013 09:10 AM
elijahblake
07-21-2010 08:31 PM
sryatt
03-16-2008 10:38 PM
vward24
02-15-2007 10:47 PM
