New clutch, pressure plate, and flywheel now my car doesn't start
Old 01-14-2011 | 09:12 AM
Peacemaker98LX's Avatar
Angry New clutch, pressure plate, and flywheel now my car doesn't start
Help!!,
I replaced all those goodies (title) and planned on putting new axels in too, as I had it all apart anyway. Before putting it all back together I figured I would try to start it to make sure all is well. It sounds like the starter is engaging, but the engine is not turning over.
98 LX 2.3 Vtec Manual Trans (obvio)
Thanks
Old 01-14-2011 | 03:55 PM
Is the starter spinning the engine?
Old 01-14-2011 | 04:05 PM
No, the starter is engaging, but it isn't contacting the flywheel.
I am thinking they gave me the wrong flywheel, however everything seemed to fit perfectly? I am stumped.
Old 01-14-2011 | 04:54 PM
Disconnect the battery.
Clean and secure all ends of both battery cables using a wire brush or some sandpaper on the bolts and connections. Also do the same check for the two connections on the starter.
Old 01-15-2011 | 09:05 AM
SOLVED,
I took the battery and starter to autozone, the starter tested fine, the battery was ok just low in charge, so I had them put a charge on it for an hour. I put it all back together and BOOYA!!!
jwelby
01-06-2014 10:19 AM
finch13
10-11-2012 06:50 PM
Willb2305
02-16-2010 01:08 AM
legionofone
04-05-2008 10:39 AM
patpatho
12-27-2006 04:50 PM
Quick Reply: New clutch, pressure plate, and flywheel now my car doesn't start
