new cv = shake
Old 09-03-2012 | 04:37 PM
mconlon's Avatar
Default new cv = shake
i have a 94 accord ex.
after replacing the drivers side cv axle my car is shaking violently. under inspection it seems like the new axle is too long. when i turn the wheel all the way to the left it will stop shaking. my motor mounts are clearly worn and the whole engine is shaking under acceleration. i already took back one axle and replaced it with a different one, however it only got worse. could the axle be too long? i purchased a reman master pro from oreilly auto.
symptoms
car shakes with rotation of wheel not by rpm
car goes faster- shake is more frequent
it stops shaking when wheel is turned completely to the right
engine shakes not wheel
new cv axle
cv seems too long
Old 09-03-2012 | 05:44 PM
Dr. Drivability's Avatar
wrong or defective axle is my guess....
Old 09-04-2012 | 06:54 PM
Need to think about replacing the mounts if they are bad.
Old 09-04-2012 | 10:24 PM
My experience is that none of the AZ, ORielly, et al CV axles have the mid-shaft harmonic balancers. I struggled for almost 2 yrs w/ vibration under acceleration of my 94EX (2 replacements w/ AZ axles) before purchasing some Raxles cv axles which include the harmonic balancer rings on the axle.
Raxles cost a bit more (roughtly twice AZ axles) but were worth it for me.
Old 09-04-2012 | 10:40 PM
i was going to mention the vibration dampners, also didn't see his motor mounts are wiped out...need those fixed as well.
JackP
10-15-2007 11:28 PM
ssc280
04-27-2007 11:13 PM
92Inspire
08-08-2006 05:07 AM
wth71
06-29-2005 04:02 PM
Quick Reply: new cv = shake
