new guy
Old 12-16-2007 | 12:59 AM
mysterysmoker's Avatar
Default new guy
Hi new to the forum. I have a 2000 accord with over 300,000 miles and I have a few questions. I have owned it since it was new, I also do a lotof my own work to it. But I do not know what the oil pressure spec is for it, what is the range? I would like to get some gauges for it but don't know what rangeI will need. Also I bought a 2 door accord bumper and mine is a 4 door,will it fit on my car. My old bumper is damaged andI need to change it out. And whould like to keep the car looking good as well as running good.
Old 12-16-2007 | 07:44 AM
Default RE: new guy
Wow, that's a lot of driving, over 40K/yr avg! My sympathies.
You've driven 300K miles and don't have a shop manual? If not, then time to get one. Even a Haynes manual will have oil pressure specs for your vehicle.
Try checking car-part.com for a replacement bumper. It provides x-over references to other models that are donors to your car, and may identify whether the coupe bumper will work on 4-dr. You may have to drill down to find the donor car details in some cases.
Old 12-16-2007 | 10:37 AM
HondatechAV6's Avatar
Default RE: new guy
Warm up the engine completely.
L4:
At Idle: 10 psi minimum
At 3,000 rpm: 50 psi minimum
V6:
At 3,000 rpm: 71 psi minimum
Old 12-16-2007 | 05:06 PM
Default RE: new guy
Thank you for the info. I don have a Haynes manual never thought to look there. Thank you again.
Old 12-16-2007 | 10:20 PM
Default RE: new guy
remove the oil pressure switch and hook up the oil pressure gauge to that.
the location varies, is it a v6 or 4 cyl.?
Old 12-16-2007 | 10:28 PM
Default RE: new guy
It is a 4 cly
Old 12-16-2007 | 10:30 PM
Default RE: new guy
I also want to have the gauge in the dash have it hooked up all the time.
Old 12-17-2007 | 07:23 PM
Default RE: new guy
honda doesn't use that type of oil pressure sensor though. it's simply an on/off switch. you'll need to get a GM oil pressure sending unit and wire it up. not fun..
Old 12-17-2007 | 08:42 PM
hondadude's Avatar
Default RE: new guy
FWIW the pressure sensor threads are a strange animal;
1/8 " BSPT
So if you need an adaptor for the guage
Frankenstein94
10-29-2014 01:02 AM
gd13
01-03-2014 12:41 AM
Seth
05-13-2010 02:40 PM
giffink
08-31-2007 08:58 AM
giffink
08-30-2007 10:16 PM
Quick Reply: new guy
