new member having little problem help
Old 04-04-2012 | 01:05 AM
rg2415's Avatar
Default new member having little problem help
I have a 2005 honda accord coupe when i turn my headlights on the illumination on radio and ac and heater controls are very low can barely see them any ideas how to fix.thank you.
Old 04-04-2012 | 03:44 AM
Hello Newbie..Please remember to read the posting rules..I moved this to this forum for you..Help will be on the way soon.
Old 04-04-2012 | 08:54 AM
crispin's Avatar
have you tried adjusting the dimmer ****?
Not sure if yours is in the same place but it in normally a wheel on the dash on the left side of the steering wheel.
Old 04-04-2012 | 11:32 AM
rg2415's Avatar
yes i tried **** n it onlu adjust the dash lights i read something about the multiplex control could this be it. and if it is can i by pass.
Old 04-04-2012 | 11:45 AM
crispin's Avatar
actually it adjusts the dash lights plus the ones you are having trouble with.
You have a bad ground.
I would add a new ground to the circuit, it is a lot of work to get to the area as you need to get to the wires going to the a/c controls.
Old 04-04-2012 | 08:09 PM
rg2415's Avatar
so u think it could be the ground dealer never seen anything like that they saying it might be fuse box curcuit board or something like that I mean i still have light just very low where i can barely see it.
Old 04-04-2012 | 08:16 PM
crispin's Avatar
Well typically whenever you have a dim circuit it is a bad ground.
Perhaps someone else will give their thoughts on this.
Old 04-04-2012 | 08:19 PM
rg2415's Avatar
thanks alot for your help.
Old 04-04-2012 | 09:52 PM
When you adjust the brightness, do some of the lights change brightness?
Old 04-06-2012 | 11:43 PM
rg2415's Avatar
no they stay the same dealer told me its the control module gauge a short im sure theres a way to by pass it they charging $400 for part and $250 labor .
Nassrif90
11-21-2013 12:31 AM
vip001
10-25-2012 08:45 PM
JC8643
10-22-2012 10:42 PM
samsteve4u@yahoo.com
03-14-2012 02:02 AM
hansw3
11-20-2008 09:25 PM
