New rims and the Offset
Old 06-30-2007 | 09:37 PM
Git2fast's Avatar
Default New rims and the Offset
Hey, im just about to get some rims and my questions is does anybody happen to know that offset on my 97 Honda Accord SE, if anybody has anything it would be greatly appreciated. Thanks
Old 06-30-2007 | 09:55 PM
Default RE: New rims and the Offset
The offset can be from 35 to 42 mm on your cars wheels, no matter who's brand you buy..
Hope this helps you out !
[IMG]local://upfiles/22/2A67C0B1A5414B2696950AD0649B48E4.gif[/IMG]
Old 06-30-2007 | 10:19 PM
Dazed's Avatar
Why is offset important? Other than the spacing between hub and rim? And what can be done to fix or mess up the offset?
I have a '97 SE too so i want to know in case i change rims/tires someday soon.
Old 06-30-2007 | 10:37 PM
The offset affects the suspensions motion ratio, which directly determines your effective spring and damper rates.
Your offset surface of your wheels is relative to the wheels centerline. The wrong offset can and will cause rubbing problems when your suspension is compressed or when you turn your wheels..
So you can see why the offset is so very important for you to figure in when thinking about buying some new shoes for that Whip of yours...
Hope this helps you all a bit more...WheelBrokerAng
[IMG]local://upfiles/22/7F6F7BAAE34742FC8D1FA54751043918.jpg[/IMG]
Old 06-30-2007 | 11:53 PM
Git2fast's Avatar
Alright thanks for the help i appreciate it, but i have another question, would these work for my car, even with the tires on it, because im doubt they do.
http://cgi.ebay.com/ebaymotors/17-Bl...QQcmdZViewItem
Old 07-01-2007 | 12:59 AM
Dazed's Avatar
How can i not affect it wen i buy new tires? Keeping it same size? What should i look for to not have the ruin my suspension?
L2_DJ
09-05-2013 05:09 AM
cardude
13
12-23-2012 01:56 PM
Jason Friesz
10-18-2012 10:16 AM
Davidokamoto
06-30-2011 10:55 PM
KEYZ
04-23-2007 06:55 PM
